Lighting for Pole Barn
   / Lighting for Pole Barn #1
budlite
Toney, Alabama
NH Workmaster 75
How many 4ft two-tube fluorescent fixtures will I need to install to light up a 30x40 metal pole barn adequately for general tractor maintenance, etc at night? I plan to mount lights above work bench areas as well.
   / Lighting for Pole Barn #3
Tally, if you haven't got your lights yet, check ebay, I got 12, 4', two bulb fluorescent fixtures with the zero degree ballast for $15. They are great. Just a food for thought.
   / Lighting for Pole Barn #5
I'm planning on 24 in my 30x48 barn, once I get busy and run some electric to it. 4 rows of 6 each.
This will give me an average of 30 fc at the work surface. I will switch them with 4 switches, and stagger them so I can adjust light level by switching.
   / Lighting for Pole Barn #6
12 years ago when I built it, I switched the lights in my father's 32'x64' barn, so he could use different levels of lighting in each area. He protested, saying it was unnecessary. After using them a while, he told me it was a great idea, and HE was glad HE thought of it. :cool:
   / Lighting for Pole Barn #7
Check your local craigslist. I bought some 400 watt hi-bay 120vlt lights with shatterproof bulbs for $15 each. They were removed from a warehouse and used very little. He was asking $20 each but I bought 8 of them. They are ready to hang and should throw out plenty of light. I see them all the time on there.
   / Lighting for Pole Barn #8
The Illuminating Engineering Society of North America (IESNA), the authority in lighting, categorizes high-bay lighting for use at 25' or higher. The ceilings of most pole barns are not high enough to efficiently use high-bay lights.
   / Lighting for Pole Barn #9
You can afford to be less efficient with a $15 light compared to paying $350 for the same light. With the lens off and my barn at 16 feet in the peaks which is not much taller than most barns. I think you can't beat the price and they are widely available.
   / Lighting for Pole Barn #10
I have 12 four footers in my 30'x40'x12 two lights per switch. It lights it up really well.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
STORAGE FEES (A54607)
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2006 International 7400 Dump Truck (A47477)
2006 International...
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
