Lightest Dump Trailer?
   / Lightest Dump Trailer? #1
keeney
Veteran Member
Minnesota
JD 4100 HST
I am looking for the lightest dump trailer I can find to maximize payload for my truck's towing capacity of apx 10,000 lbs.
I also want to be able to fit my tractor in the trailer, so I need at least 12' long. 14' long by 80" wide would be the ideal size, but I am not sure I want to add the extra weight.
To make loading easy, I would want a low-profile, drop-axle setup.
The lightest I have found in the 12' length is about 3500 lbs, and the 14' all are very heavy duty, coming in around 4500 lbs.
Anybody know of a manufacturer who makes an aluminum dump trailer?
- Rick
   / Lightest Dump Trailer? #2
Rick,
My 12'x6', 10,000 lb gross dump trailer weighs 2500 lb empty. At least that is what it says on the data plate. Mine is not a low profile design. But, you want to be careful about getting a light weight dump trailer. There are a lot of stresses applied to the box frame and trailer frame when a heavy load is being dumped. You want a strong (heavy) frame to hold up to those stresses.
Jeff
   / Lightest Dump Trailer? #3
I'm with Jeff on this one. I have a 6'X12' 12,000 low-profile dumper from Anderson Mfg. in GA. The empty weight is 2,500 lbs. It does not have a drop axle, so the bed is about 30 inches high. I have not tried to put my Cub in the trailer, but it should fit. I use it to deliver firewood.
I would be more worried about tow vehicle than I would about an extra 1,000 pounds of payload weight. There are not a lot of vehicles that you can tow and dump safely at this weight. That trailer puts a lot of stress on the hitch when that load starts to move off the trailer. I use an 8,000 pound Excursion with a class IV hitch. You also have to worry about the GVWR/GCWR on your vehicle registration with a heavy trailer.
I would not touch an aluminum trailer in this weight class. Not only the loads on the frame, but lifting a heavy load to dump it when you are not on level ground can be very tough on the trailer. I've seen a heavy dump truck twist like a pretzel when the load shifted while dumping.
   / Lightest Dump Trailer? #4
I have a 14000 # dump trailer, 14' by 80 1/2 " wide, it has a 10000 # payload and weighs about 4000 #'s, it is made by Us steel products, it fits my 3830 with no trouble. I think the hitch is the weakest point, I pull it with my F350, the truck has no trouble but the hitch takes a lot of stress when I put 10000# 's of rock in it....
2008 Polaris Ranger XP Sportsman 800 4x4 Utility Cart (A42744)
2008 Polaris...
WITTIG VACUUM PUMP (A45046)
WITTIG VACUUM PUMP...
1998 INTERNATIONAL 9400 6X4 POLE TRUCK (A45333)
1998 INTERNATIONAL...
2018 Triple Crown 8ft Utility Trailer (A42742)
2018 Triple Crown...
New/Unused Greatbear 78in Grapple Bucket (A44391)
New/Unused...
2006 TANKCON FRP INC. 130BBL FIBERGLASS ACID TRAILER (A45333)
2006 TANKCON FRP...
