Lifting the MMM on a 2210
   / Lifting the MMM on a 2210 #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
A friend of mine came and said he had a problem with his 2210; he had thought that my tractor was a 2210, too. His MMM won't lift.
How is it attached to the 3 ph on a 2210? He probably just lost a pin. Is it possible to lose one pin such that the whole deck wouldn't lift? I'd think it's attached to the lift arms at the back end and that one side would lift but not the other of one of them lost its pin. How are the MMMs attached?
Ralph
   / Lifting the MMM on a 2210 #2
Kind of hard to explain without a photo handy, but I'll try.
Looking at the rear of the tractor, look at the left 3 point hitch arm. About half way up that arm, there is an "L" shaped bracket that is attached to linkage that goes toward the front of the tractor just above the rear axle. When you raise the 3 point hitch, the left arm should catch that "L" bracket, and pull the linkage rod. Also be sure he has the spreader bar on the 3 point hitch keeping the arms spread apart.
Just follow that linkage rod forward and you can see where it attaches to the lift mechanism under the center of the tractor forward of the left rear tire.
A common thing with this setup, is that the linkage rod from the 3 point hitch going forward gets bent from improper adjustment. Take a good look at the whole linkage setup.
Looking at the above diagram, part #23 is what is supposed to catch on the left 3 point hitch arm as it is lifted. Part #21 is the rod that goes forward and sometimes will get bent.
   / Lifting the MMM on a 2210 #3
I will bet this is the problem. If you take the draw bar off the 3 point hitch, the mower deck will not raise any more. You need to have the draw bar on in order to hold the lift bars spread so they make appropriate contact with the lifting hardware for the Mower deck. Don't ask me how I now this.
2019 JLG 2632ES 26ft Electric Scissor Lift (A55787)
2019 JLG 2632ES...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
2018 Ford Fusion Sedan (A55758)
2018 Ford Fusion...
2006 Deere 410G (A53314)
2006 Deere 410G...
2020 Kubota KX040-4 Mini Excavator (RIDE AND DRIVE) (A50775)
2020 Kubota...
