Lifting Rotary Cutter on Turns
   / Lifting Rotary Cutter on Turns #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I was reading the operator's manual on my Land Pride cutter last night and noticed a comment:
"Make wide turns when possible. Three-point hitch and
optional Quick-Hitch models can be lifted into transport
position to make tight turns
and to reverse direction."
I've never lifted my cutter to make a turn (and I do have to make sharp turns) although I can see it being easier on the 3PH draft links and where they attach.
Does anyone lift their cutter to make turns? Just curious...
   / Lifting Rotary Cutter on Turns #2
Everything except the lawn tractor. My pocket knife even gets lifted.
   / Lifting Rotary Cutter on Turns #3
I only lift if the ground is rough. If I am in an area where it is pretty level and smooth, no chance for the side plates of the cutter to contact a ridge or mound of dirt, then I leave it down. Should be rolling along on the rear wheel, can't see where that would hurt a thing.
   / Lifting Rotary Cutter on Turns #4
I very seldom ever do unless I turn using the brake. I have done it on occassion in very rough ground because you could bend your lift arms or the side of the rotary cutter if it would catch something. It is probably a good idea not to make sharp turns with it down.
   / Lifting Rotary Cutter on Turns #5
Not usually, if I were to make a turn using a brake I would, or in soft ground.
In most cases I make sure my tailwheel is in good shape and expect it to do its job. I would think there are some people who don't understand the stresses placed on the 3pt with an implement that extends so far beyond the rear of the tractor and the verbage is in there for that reason.
   / Lifting Rotary Cutter on Turns #6
I am pretty much in agreement with everyone else. As jenkisph notes, unless you exceed common sense loads by really fast, sharp turns or contact with something that will generate undue force, you won't have any problems. Even then it will probably require repeated stressors to do damage in all likelihood if your equipment is properly matched.
   / Lifting Rotary Cutter on Turns #7
I never lift on turns, however, there would probably be a lot less stress on my cutters tail wheel if I did. Ken Sweet
   / Lifting Rotary Cutter on Turns #8
I lift as much as NASCAR drivers do (not often!)
   / Lifting Rotary Cutter on Turns #9
I'm in the minority, I usually lift the mower if it's a tight turn. Probably the only reason I think to do it is because mine's a Land Pride as well. That's from reading the manual, I guess... I find the mower doesn't cut well if the turn is too sharp anyway, the mower moves too quickly to cut cleanly as it's crabbing sideways over the ground.
I'm more concerned over the stress on the 3 ph than the mower.
Sean
Sean
I think I'm going to join you (for the same reason). After all these years of never raising a rotating implement...kind of goes against my safety mentality.
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2017 Nissan Titan SV Crew Cab Pickup Truck (A48081)
2017 Nissan Titan...
2019 Allmand Trailer Mounted Light Plant (A50860)
2019 Allmand...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2016 Nissan Pathfinder AWD SUV (A48082)
2016 Nissan...
