Buying Advice lifting abilty in compacts- looking for a second smaller tractor
   / lifting abilty in compacts- looking for a second smaller tractor #1
WVfarmin
Mahindra 6530
Hi,
Due to a change in my husbands work, this winter I will be tasked with putting out round bales for our cattle. Our rounds are prob 800-900 lbs dry. I have to confess I am terrified of his 6530 Mahindra. Its huge, has gears and levers sticking out everywhere, and as soon as you let off the clutch you are moving. Yes, I know, I'm a wimp. But the fact our barn has literally inches between the pole beams and the rear wheels requires one to be really good spearing and taking out bales. I have visions of me taking out the barn at 1mph....until he got used to the tractor, HE took out a few posts...ahem. needless to say, while that tractor is awesome for brushogging fields fast and heavy work, Id really like something smaller and easier to maneuver, as well as less compaction to the ground in the winter mud/freeze. the ruts that thing makes are enormous. There are a few 3010 kubotas in our area but I wonder if they can lift a larger round bale without falling over on their nose, esp since our are stacked. I also am considering a smaller Mahindra, like a 1526, but again, wonder if it is too small. I basically don't want to spend a ton on a second tractor, and we don't need another beast tractor, but just one big enough to put out hay and do the lighter easier work and be hydrostatic so I have less to freak out over when I am by myself.. I also would not mind helping hubby brushog, two tractors would make shorter work of it. We live in WV and NOTHING is flat. So it is a big learning and confidence curve for me ..oh and my day job is in a hospital where I see all the guys who flip their tractors...every year at least 2-3.......so I come by my wimpiness honest. Thanks!
   / lifting abilty in compacts- looking for a second smaller tractor #2
I would think if I were to be lifting 900lb bales on a constant basis safely, I would be looking for a lift capacity of 1400lbs. So maybe, around 40hp in hydro with sufficient ballast.
   / lifting abilty in compacts- looking for a second smaller tractor #3
Used forklift in the barn. Big tractor in the field.
Bruce
   / lifting abilty in compacts- looking for a second smaller tractor #4
My new Branson 4015 is a pretty small tractor, about the size of the 3000 series Kubotas, yet with the new BL150 loader it can lift 2200lbs to full height. Pretty amazing really.
The 15 series Branson sounds right up your alley. The hydro-max transmission automatically brings engine speed up or down based on pedal, perfect for what you will be doing.
   / lifting abilty in compacts- looking for a second smaller tractor #5
I would have a lot of use for this myself, my next tractor will have auto throttle..
   / lifting abilty in compacts- looking for a second smaller tractor #6
I had auto throttle on my Kubota and I didn’t like it at all. What do you guys find appealing about it?
   / lifting abilty in compacts- looking for a second smaller tractor #7
An L3010 kubota is too small to lift a 900 pound round bale. I think a LA724 or 7 whatever the newer model is is the smallest kubota loader to do the job.
   / lifting abilty in compacts- looking for a second smaller tractor #8
I was thinking it would be handy for loader work to not have the rpm's high all of the time, I do mostly loader work with my tractor.. What did use you tractor for and why didn't you like it?
   / lifting abilty in compacts- looking for a second smaller tractor #9
It wasn’t proportional to the pedal travel. It was at nearly full rpm at 1/4 of the pedal travel used. And it reved to like 2700 rpm regardless of work load. I much preferred to set the rpms around 2000 unless more or less power was needed and adjust as needed. Overall I liked my Grand series tractor a lot better than the standard series.
   / lifting abilty in compacts- looking for a second smaller tractor #10
Just learn to run the big tractor. Put some seat time in. You’ll get it. If it’s beyond you, you’ll know after a couple days.
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
Behlen Country 3 pt Leveler (A50514)
Behlen Country 3...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
