Lift won’t work
   / Lift won’t work #1
Brushyface
53 ford jubillee
I’ve got a 53 ford jubillee that the hydraulic pump is working fine on but the lift won’t work. Could it be the relief valve? Thanks
   / Lift won’t work #2
It could possibly be relief valve. How do you know the pump is working? Did you do a pressure check? Do you have a front loader or just the three point? It may sound dumb, but how's the fluid level?
   / Lift won’t work #3
PTO must be engaged.
Clutch must be engaged.
For the 3 point to work.
   / Lift won’t work #4
Put it in neutral and turn pto ON because a jubilee is like an 8n. But the pump on a jubilee is external. Could be trash in check valve. Could have a bad ring on lift piston. Old ones were leather so if it's not been in use lately...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2010 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A54607)
2010 MITSUBISHI...
Mongo Mover Aluminum Hand Truck (A52377)
Mongo Mover...
2007 CHEVROLET SILVERADO TRUCK (A54756)
2007 CHEVROLET...
