Lift swap from an 881 to an 860
   / Lift swap from an 881 to an 860 #1
jeff pk
OR
1960 Ford 641 1957 Ford 860
I'm going to tackle this soon. and was wondering if it's as straight-forward as removing one, replacing two o-rings and gasket, and putting the other in? What should I check as far as the condition and adjustments on the one (881) which is going into the 860 and will be the user? It lifts good and stays up without leaking down. The 860 has a cracked top-cover and leaks down fast and only lifts at the upper part of the quadrant.
Thanks for any guidance or suggestions...
   / Lift swap from an 881 to an 860 #2
if the lift on the 881 works fine.. lifts good and don't leak.. then yeah.. swap can be as easy as a top cover gasket and those 2 small orings.
don't ditch the 860 cover. post details of the crack. there may well still be good parts on it...
I long while ago I bought a used cover from John Smith and I never around to installing it. I plan to transfer all the parts from the 860 lift onto the new cover and see if I can get it working properly...
   / Lift swap from an 881 to an 860 #4
should be no issue.
basic coverdoes nothing more than provide a place to mount stuff to.. and has some ports.
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
78'' skid steer bucket (A53421)
78'' skid steer...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53473)
2018 John Deere...
