blackd
Platinum Member
My FX24D has been doing some crazy things on and off for the past year. Losing power, especially when cutting on a steep grade, then coming back strong on the level. Odd little misses and power losses. Been chasing it for nearly a year.
Knew it was fuel related and finally this week it became consistent. I have a Fuel Lift Pump. Well the tractor does anyway, and it is flat not pumping.
System works like this: 1) Gravity feed to pump; 2) Pump lifts fuel to filter; 3) Injector pump picks up fuel from filter, 4) Excess goes back to tank. After filling the filter housing, I can watch it empty, then tractor falter as fuel reaches bottom of filter. Pump must pick up just enough to keep it barely running, but not enough to fill the filter housing once emptied.
First time I've seen this mentioned on here. Anyone have a newish Yannie with pump?
