lift link turnbuckle-no locknut
   / lift link turnbuckle-no locknut #1
scott36854
valley,al
JD 3038e
i am new at this entire utility tractor experience, but what type of turnbuckle is it that has a section that you lift and turn rather than the one with a locknut like came on my 3038e? looks like the lift and turn type we be so much easier. is there one for the top link with a lift and turn type mechanism?
   / lift link turnbuckle-no locknut #2
:welcome: to TBN
I'd ask your Deere dealer if yours can be retrofitted with the lift and turn linkage.
May be someone here will know better than I too.
   / lift link turnbuckle-no locknut #3
You can swap it out with a lift and turn, just get one that will match up the extended and retracted length of your existing one. Might be a good time to swap with a top link cylinder from Fit Rite Hydraulics too. That would be the easiest to use imo.
   / lift link turnbuckle-no locknut #4
Typically for Deere anyways you will normally find that most compact tractor oem center links are of the locking nut design. Kind of went back and forth on lift links but usually where of the lift and turn design. The style of center link I would look for if wanting to get away from the locking nut would be a version that has some form of a fold away handle. When the handle is folded out you could freely adjust center link, when the handle is folded back onto the body it acts as your locking device. This is the style you will see on most current Deere machines at or above 5xxx series (unfortunately many of those will be to big for your tractor). Many general purpose replacement center link styles will have a large tab that sticks out that operates as your locking nut that you could release without a wrench. You can get that style from Speeco or through Deere's match plus line and I imagine many other outlets. But I'll have to state unless you have the locking nut torqued down terribly tight normally you could adjust the center link in the opposite direction to take tension off of the nut and then move the nut by hand. I could be wrong but I think the biggest issue with a lift and turn design is that it is expected that the link will always be positioned vertically, center links depending on your application could potentially be at a slight upside down incline when fully raised that would allow the locking sleeve to slide off the retainer.
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
