lift capacity
/ lift capacity #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
I have a l3300 with la480 fel.
lift capacity never did seem that great but now it want lift a full bucket of dirt. reving the motor does not seem to help. is there an adustment for the amount of hydrolic preasure?
/ lift capacity #2
You may have the pressure relief stuck partially open in the control valve. Ask your dealer for a breakdown of it.
Before you go and change pressures, get a gage to measure the pressure at the lift cylinder. Tee in to the line at the cylinder.
jb
/ lift capacity #3
I read here once that if the three pt hitch isn't adjusted correctly by the dealer and is all the way up it can impact in a negative way the lifting capacity of the fel. It was said to lower the three pt slightly to correct this and the fel would work with the correct power. I'd try it before starting anything else just to see. I don't want to get flamed, just repeating what I read.
/ lift capacity
Any idea what the preasure should be?
also never would have thought the 3 point all the way up would make a differance I'll try that also
/ lift capacity #5
Not sure, but normally around 2500 psi for most models. Some adventursome folks have shimmed up to 2700-2800.
If the 3pt is up all the way, and not adjusted correctly, it could be bypassing the pressure relief.
jb
/ lift capacity
What kind of adjustment are you talking about?
the linkage valves or what?
any ideas on doing this my self?
thanks for the help
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
