Lift capacity of 758C on a TC34DA
   / Lift capacity of 758C on a TC34DA #1
Dave1953
Claremont, NC
5000 Ford, 2019 New Holland Boomer 55 Cab, 935GBH BH
Does anyone have an idea of how much weight can be lifted by a 758C backhoe on a TC34DA at say 6' from the rear of the tractor. Just trying to get an idea of how much I can lift if I bur a thumb for my BH.
   / Lift capacity of 758C on a TC34DA #2
http://www.delclayfarmequipment.com/pdf/UtilityBackhoe.pdf
New Holland Agriculture 2008 758C Backhoe Implements
Not sure how you would get those specific figures since it is really outside the realm of what backhoes are used for . I Know My 758C attached to My TC30 with a manual thumb will pick up a fairly large chunk of log . I was moving 30' long logs of Madrone , ( similar to Oak ) that were 12" + in diameter out of the deck to block them up . Although I was Not lifting whole log , I was lifting one end , then rotating the backhoe to slide it out . Did it without issue's .
Fred H.
   / Lift capacity of 758C on a TC34DA #3
Dave, we used my 758C on a NH1920 to pick up a 350 GM engine but it could not lift it with the boom and dipper fully extended. Also have lifted a 250 lb vibratory compacter into and out of an 8 foot basement. Bill C
Thanks for your input. Dave
Engine was probably about 500 lbs. I can see where it wouldn't pick it up fully extended. That's a long way from the tractor. I guess I will just keep using the FEL for the heavier stuff.
Dave
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2003 HEIL KILL TRAILER (A52472)
2003 HEIL KILL...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
