Loader Lift Bucket Problem
   / Lift Bucket Problem #1
Mike Eagle
I am a new member and I just posted a thread in probably wrong section (hydraulics). I have a 1964 MF 165 with a MF 235 front end loader. The lift bucket will not stay in position when it meets any resistance. When scooping the bucket will either bite into the ground or ride up over the pile of material. When scrapping the bucket easily moves out of position. I have a Cross controller with two 4-way valves, one for the lift and one for the bucket. The valve for the lift has a float position. I have replaced all the seals and O-rings in the bucket cylinders, although they really did not need them and the Cross valves have been disassembled and there are no sign of any possible problems here. The hydraulic system has no leaks and is powered by a separate aux pump connected to the engine.(plenty of flow).
Anyone have any suggestions as to what the problem may be?
This problem must be harder than I thought. Surely someone has had a similar problem.
   / Lift Bucket Problem #3
Mike,I have a similar problem w/my 165,yours sounds like the spool valves are leaking by,the spools are the only thing that holds the fluid to keep the bucket in place.
Thanks jimstrac. Did you find a solution or just live with the problem as I have been doing? When and if I ever solve the problem I'll post the info here. Thanks again.
   / Lift Bucket Problem #5
I'm still trying to figure out mine,the next step will be to install psi gauges to pin point the problem.
jimstract, I found my problem. You can see my solution under the hydraulics forum, same title. Good luck.
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2020 Kia Sportage SUV (A50324)
2020 Kia Sportage...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
John Deere 843 Corn Head (A50514)
John Deere 843...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
