Mike Eagle
- Joined
- May 24, 2010
- Messages
- 15
I have a 1964 MF 165 with a MF 235 front end loader. The bucket seems to have a mind of its own. When I try to scoop it either digs in or rides up over the pile. When dragging with the loader the bucket releases and does not stay in position when the tractor moves. I have replaced all seals and O-rings in the bucket cylinders. The Cross, 4-way control valves for the lift and bucket have been inspected and no problem areas found. The lift valve has a float position. All equipment is original. No leaks in hydraulics. It has a separate fluid pump driven by the engine. Anyone have any suggestions as to how I might solve this problem. Thanks.
