Lift arms won’t lower - ShenNiu 254
   / Lift arms won’t lower - ShenNiu 254 #1
Ken Djnak
ShenNiu 254
Bought an older ShenNiu 254, with a box on 3-PT hitch. Parked it a couple of months, arms/box down.
Re-start, 3-PT went up once to allow me to swap out teeth.
Now, it won’t lower. I thought it was gravity only (not hydraulic push down). Fluid is a bit low.
Is there a check valve or some other reason why it won’t lower?
Thx.
btw- I have a full “English” version of the manual, about 150 pages.
   / Lift arms won’t lower - ShenNiu 254 #2
You should have a valve with a knob that adjusts the speed that the 3 pt arms go down and if fully closed, it will actually lock the arms position and won't let it go down.
On most tractors it is located pretty much under the seat in between your legs. Yeah, sounds weird but makes sense once you see it. On Chinese tractors, I'm not sure because they do some funky stuff with the placement of the controls.
2019 Challenger MT738 Track Tractor (A53342)
2019 Challenger...
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
New Long Forks (A53002)
New Long Forks...
CONTACT INFO (A53084)
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
