Lift arm malfunction due to stuck dump bed switch
   / Lift arm malfunction due to stuck dump bed switch #1
ndnewbie
North Dakota
Toolcat C
Thought I would post this in case it happens to someone else. I didn't notice a similar post here.
Symptom: Lift arm on my TC raised normally when I pulled joystick back. However, rather than going down when I pushed the joystick forward, it raised further, seeming to struggle. It would go down when I pulled out the lift arm by-pass, but repeat the problem as again tried normal operation. There were no error codes. The tractor engine also had a slightly different sound to it, feeling a little rough. The cooling fan came on, indicating a work load I did not expect. This was what lead me to the solution.
Solution: I had previously used the dump bed. I found the rocker switch lowering the dump bed had "stuck" as I was lowering it, activating whatever valves are activated to do that. When I freed the rocker switch to its normal position, everything immediately returned to normal. Yippee.
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
1269 (A50490)
1269 (A50490)
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
