Toplink Lift arm adjuster
   / Lift arm adjuster #1
Burtonbr
NC
Kubota b2620, LA364 loader.custom rear remotes, THUMB bucket grapple, 60" box blade 72" landscape rake &many other toys
Not sure lift arm adjuster is the correct name for one of these, but I'd like a easier way to adjust the tilt than having to twist the turnbuckle .
Can you buy one like this somewhere. I haven't seen any for sale other than the standard type.
   / Lift arm adjuster #2
This place has 3 pages of side links. The last page has one like you want but it would take some work to make it fit.
Leveling Rods & Side Links - Three Point Hitch - Accessories
Another option would to put a hydraulic side link on it but you would need a rear remote.
If you pick up and let the implement down while you are adjusting it makes thing easier.
   / Lift arm adjuster #3
Search TnT or Top n Tilt or Fitrite you will get more info than you can read.
Or PM Mtnviewranch
   / Lift arm adjuster #4
My stock one is similar to that one, but mine was real stiff when I bought the tractor. I removed it and put it in a vise to get it to turn a little smoother with a pipe wrench. I guess that whole procedure combined with the rust wore the threads out enough that the threaded shaft pulled out of the threaded tube and my finish mower came crashing down and bent the treaded shaft. I don't use it a lot so I leveled it and welded it place for now. Replacing it from JD will cost me more than getting the hydraulic one from fit-rite, so as soon as I get some rear remotes I will buy one from them. In the mean time I will just deal with the "fixed" one.
   / Lift arm adjuster #5
thats a stock side link for a new holland delux hitch.
i keep mine greased and its a brease to adjust side tilt when there is less than moderate weight on the 3pt. still hard to turn if there is a lot of weight your trying to lift, at which point you can raise/lower the 3pt at the same time as you crank that handle to make it go easyer.
otherwise invest in a hydrulic side link and rear remotes
2003 INGERSOLL RAND SD-105DX SMOOTH DBL DRUM ROLLER (A52707)
2003 INGERSOLL...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
PALLET OF MISC RIDGID TOOLS (A55745)
PALLET OF MISC...
12 ft Shipping Container (A55973)
12 ft Shipping...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
