Life of tires
   / Life of tires #1
MillWeld
Durham NC
Ford 641
I've been told that the life of a trailer tire is about 7 years regardless of mileage. I presume this is true for any low mileage vehicle - if you don't wear the tread off driving then the tire rubber deteriorates in that time period. Correct? But what about farm tractor tires? I purchased a used Ford tractor in 1987 and I am still running the same rear tires - they have very worn treads but it suffices for my needs: mowing and pulling logs primarily. I use it about 150 to 200 hrs a year and with no flats or bursts. All my vehicles are housed under cover.
Bob
   / Life of tires #2
Tires left out in the weather will deteriorate faster than if stored inside. Using the tires helps. My Titans are 13 years old now and still fine.
Keeping them inflated and a tire dressing will help if stored outside.
   / Life of tires #3
I dunno. I bought a used 16', two axle trailer from the late 90's and I'm sure the original tires were on it. One finally did start leaking enough (tubeless) thru cracks that I put a new set on it...but my guess is they were working on 20yrs old.
One set I wear out pretty quick is the front tires on my 4x4 tractors. I seem to get about 500-600 hours on them, and they are worn slap out.
   / Life of tires #4
Go to the RV forum , woodalls and read about ST trailer tires and LT truck tires . Its quite fun to read
   / Life of tires
Is the RV forum part of TBN? If so, I missed it. Got a link to it?
   / Life of tires #6
I have two garden tractors built in 1967 that are still riding on the back tires that came with them new. It seems the rubber back then cured harder and lasted much longer than today's tires.
   / Life of tires #7
The 7 years is for Hwy speed tires, not for slow seed tires like ag & garden tractor tires.
   / Life of tires #8
I have never seen a trailer tire fail because of tread loss. Their life is fairly short before they blow out.
   / Life of tires #10
We have a 1971 4020 and the rear tires have been replaced once.
KUBOTA ZD1211 (A53084)
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
