LGT45k54 drain plug loose
   / LGT45k54 drain plug loose #1
ottawarob
Ottawa, Ontario
BCS, MF 1540
I'm sure this has been covered before, but I can't seem to find anything in the search history. I changed the oil on my lawn tractor the other day, noticed that the drain plug for the oil is loose. I can finger tighten it, but there isn't enough clearance to get in there with a wrench or socket - does husky make low profile socket to tighten this up, or do I have to start taking off parts to get in there and tighten it?
Well, it's super not ideal, but I managed to get some needle nose pliers in there and snug it up pretty well and also not strip the heck out of the bolt. Time will tell how that holds. Some sort of needle nose adjustable wrench would be great for this.
   / LGT45k54 drain plug loose #3
Assuming that you have the drain under the starter on yours, pull the starter and secure it. I use one of two crow's foots. It would be best if you have time to drain complete , dry and use some Permatex on the threads or other thread seal Loctite .
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
ASSET DESCRIPTIONS & CONDITION (A54313)
ASSET DESCRIPTIONS...
