Leveling posts ?
   / Leveling posts ? #1
hosspuller
Veteran Member
Piedmont Triad, NC
Didn't intend to have a Deere fleet - it just happened 310C, F915,102, 5200 & 5065E
I'm planning a 20' x 36' pole shed. There will be two rows of posts every 12 feet separated by 20 feet. Once the posts are vertical in the ground, I need to trim the tops level about 12 feet above ground for the trusses. How would a person determine the level plane on the posts? Use a line level and string ?? Work from one post around the perimeter and hopefully end up at the starting level??
Don't have any exotic equipment like a laser level.
Your experiance is appreciated...
   / Leveling posts ? #2
"Exotic" :laughing:
Your best bet is to rent a laser for the day.
   / Leveling posts ? #3
You can use a clear plastic tube and water. The level of the water on one end of the tube will be exactly level with the other end.
   / Leveling posts ? #4
Rotary laser without a doubt.
Shoot a benchmark on the posts and simply measure each post and with some calculation, cut them all to the correct length.
   / Leveling posts ? #5
yup...yo can rent these very cheap for the day. also use them to set the marks for the 2x6 stringers so all will be even and level.
   / Leveling posts ? #6
I'd ditto the suggestions to rent a good outdoor spinning laser level and shoot marks on all your posts. Maybe shoot some grade marks while you've got it. That will come in handy when you reestablish the soil or put down gravel.
A line level will work, put it exactly in the middle of the line to get the best accuracy. Pull the line very taut to mark the intermediate posts accurately. It's more important that you have straight lines than it is that they be dead level. A wavy roof of floor is more of a problem than one that's a bit out of level.
Water levels aren't so easy to use unless you have two people, or one of those audio alarms that go off when it's at a set point. They also have to be large enough in diameter to not resist the small motions of the fluid column. And you need to make sure there's no trapped air. If you do it, get clear plastic tube and tint the water with food coloring so you you can find the air bubbles.
   / Leveling posts ? #8
I used a water hose with clear tubing on each end. It works, but slow. However, you can measure level out of line of sight, like around corners.
I have also just leveled one board at a time as I went around the barn and that worked.
   / Leveling posts ? #10
I just did this my self i put up a 24 x32x10 pole shed. The way i did it was measure 10 ft on one cornor post and then levelled each board with a 6 ft level as i went. seemed to turn out ok.
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
23311 (A51694)
23311 (A51694)
