Threepoint
Veteran Member
- Joined
- Feb 13, 2014
- Messages
- 2,233
- Location
- No. VA
- Tractor
- Kubota B2150HST w/ LA350 loader, Kubota GF1800 HST, Kioti CK3510SE HST w/ KL4030 loader, Kioti NX4510HST/cab w/ KL6010 loader
Our NX4510 has the KL6010 loader. The level indicator for the bucket looks to be the same as on the DK series loaders, and probably others, so I'm hoping someone has a suggestion on this.
When the bucket is level, the top of the rod is actually about 1/2" below the top of its sleeve, so can't be seen from the cab. Not a big deal, but 1/2" might as well be 2" if you can't see it. So I end up wasting time fine tuning the bucket tilt.
Is there any way to adjust the length of the rod? There isn't enough thread at its base to raise the height. One thought I have is to drill and tap the top of the rod to receive a stainless steel machine screw with the head cut off. That way I could adjust it level with the top of the sleeve. All thoughts welcomed.
