DrRod
Platinum Member
- Joined
- Apr 25, 2005
- Messages
- 881
- Tractor
- John Deere 4110
Greetings,
OK, more arcane questions this morning (can you tell I've been reading my manual? /forums/images/graemlins/grin.gif )...
So my LX4 mower isn't level after about 6 hours of use (hitched to JD 4110). So I notice some clean threads on the right-side shaft and think -- hmm, this appears to have vibrated and creeped around a bit, lowing the right side draft link and in turn the mower deck. So I try to turn the lift link body to raise it back to where it was -- but man is it hard to turn. So I raise the mower and lower it back down on a 4x4 to take the weight off and I can then turn it -- but its still pretty hard. I got it back level and tightened the locknut and then noticed that my locknut is on top of the lift link body -- not below as shown in the manual.
So here are the questions:
a) should the locknut be on the bottom or does it matter?
b) is there an official way to take the weight off the link lift so it turns easier?
c) is there a tool I should be using to turn the lift link body? (it has a metal loop on it which would accomodate a lever but I was reluctant to break it)
d) is there anything else you might suggest to keep it from de-leveling in the future?
Thanks for your help -- again.
Rod
Rod
