Let it snow
   / Let it snow #1
ronjhall
Super Star Member
SW Oakland County Michigan
2, Kubota B2910 HST
Finally took a picture of my 2910. Just finished installing a Curtis 6 ½' snow blade. But need enough snow to use it. Have a Happy Thanksgiving.
ronh
   / Let it snow #2
Ron,
That's a nice looking blade. I use a back blade and it works well for me, but I'm sure not as well as a front blade. You're on the wrong side of the state for snow this week! I've got over 6" here in the Battle Creek area and a co-worker of mine that lives west of US-131 told me yesterday that he has gotten about 24" so far! /w3tcompact/icons/cool.gif
JimBinMI
   / Let it snow #3
ronjhall,
Won't take long to clean your driveway with that great looking setup.
Now don't play in the street during a snow storm just to have fun, /w3tcompact/icons/wink.gif
I'm sure your neighbors will be drooling as they watch you,and just might ask you to plow them out. /w3tcompact/icons/smile.gif
May you and your family have a safe and pleasant Thanksgiving holiday.
Thomas..NH /w3tcompact/icons/wink.gif
   / Let it snow #4
Looks nice. Looks like it may be a bit overkill for that sidewalk though. LOL!
Paul B
<P ID="edit"><FONT SIZE=-1>Edited by s1120 on 11/23/00 07:52 AM.</FONT></P>
   / Let it snow #5
Ron looks like a great setup... May I ask how you went about attaching it?
The Ben from MA /w3tcompact/icons/cool.gif
   / Let it snow
Ben thanks for the good words. I installed the blade using the kit that Curtis supplies. Check out the picture attached. When a blade is ordered from them, the size of the pin in FEL and cylinders is required. I did have to weld the brackets that connect FEL to the blade assembly. The part that took some work was hooking up the valve for changing angle of blade. I purchased the rear hydraulic output port from Kubota to get oil to the valve. I mounted the valve underneath the FEL valve. The Blade weighs 500 lbs. So extra weight is needed at rear of tractor. Not wanting to load tires or add weights. I have ordered a new back blade. The Land Pride RB1572 that I bought with tractor weighs 260lbs. The heavy duty RB3572 weighs 460 lbs and gives me more options when using it. My dealer is giving me what I paid for the original one back, to apply toward the new blade. I have purchased tire chains [www.tirechains.com] for the front and rear tires. Tire chain on the right rear hits fender. I'm going to make a spacer to move axle out 1". Should have that done in the next couple of weeks. May not need the rear chains. One of the forum threads had a note about only using the front chains anyways. I haven't decided what type of extra lighting I'm going to add. But I have seen some good ones on this discussion forum. Saw some nice ones at my local marine store, Good price,$30 for 2 and made with stainless steel.
But still no snow for a good tryout. Let you know how well it works when we get some deep snow on this side of Michigan. Everything looks like California mud today.
ronh/w3tcompact/icons/cool.gif
   / Let it snow #7
Do you have plenty of power for pusing that blade? When I get my compact tractor I am thinking about getting one.I want to know because I plan on getting a larger tractor than you have.
   / Let it snow
My tractor has more than enough power to push snow with the 6 ½' blade. The problem will be having enough traction to push the blade. With 4WD I will be able to raise the blade slightly off ground, which will put a lot of weight on the front axle. With chains on the tires I should have enough traction to push snow even on ice.
   / Let it snow #9
Ronald,
Do you have counter balance on the rear end so the tire chains can get a better bite.
   / Let it snow
The only weight I have is a Land Pride 3572 Rear Blade. It weighs 460 lbs. That's 100 lbs more than my 60" Box Scraper. I have not had to move any snow yet. I did grade some dirt with this setup. Did a great job. Didn't load my tires. Don't want the weight for mowing the lawn in the summer.
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
Electric Mobility Scooter (A51694)
Electric Mobility...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2020 Ford Transit 250 Cargo Van (A51692)
2020 Ford Transit...
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53473)
Mitsubishi FG35...
