Lesson Learned: Pros Don't Always Do It Right.
/ Lesson Learned: Pros Don't Always Do It Right. #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
Okay, this is not directly tractor related, but the concept translates to all fields of interest. Don't assume that because it was done by a professional it was done right.
I just spent 3 hours chasing some gremlin in my clothes dryer that wasn't even there. In the end the problem ended up being the outlet that a licensed electrician had just moved for me.
The dryer was acting like it wasn't getting any juice. I started with the assumption that the temporary box was good that the electrician had put in to get us by during our remodel in between tearing out the old wiring and installing the new. After all, it had worked a week ago on the same box.
Everything in the dryer checked out. I mean EVERYTHING. So, I started tackling the outlet. I got 135 volts from one leg to neutral, and 90 volts from the other leg to neutral. I had a solid 240 between the two hots.
In the end I found that the neutral wire of my 125/250 volt outlet was wired to the bare ground wire (the ground isn't hooked up yet. That's part of the remodel). I wired it correctly, and voila! It works now. I think the reason it was working last week was because the ground was shorted to the neutral somewhere along the way. In the process of moving stuff around I must have "unshorted" it.
Anyway, it works now; and I have learned once again that just because I pay someone to do something that I am too lazy to do doesn't mean that it's done right.
/ Lesson Learned: Pros Don't Always Do It Right. #2
I have been there. I think every profesional gets in a hurry from time to time and flubs there work.:confused3:
/ Lesson Learned: Pros Don't Always Do It Right. #4
The pros which pat themselves on the back are the ones get my feather ruffle w/sloppy workmanship..just be honest and say I can't or not sure I fix it.
/ Lesson Learned: Pros Don't Always Do It Right. #5
I've found over the years to a "pro" sometimes it is just a "job". Often times an "amateur" is passionate about it and does a better job than the so called "pros".
Some years back I told a local Ford dealer about a TSB on my truck. The service writer told me he disliked people telling them "what to do". He had to eat a little crow when he looked up the TSB, which the "pro" service writer had never heard of:ashamed:
/ Lesson Learned: Pros Don't Always Do It Right. #6
The only "PRO's" I ever met all said the same thing "Every day I learn or atleast try to learn something new!" A "PRO" that thinks they know it all, are NOT pro's at all!
/ Lesson Learned: Pros Don't Always Do It Right. #7
Tractor related!
A pal who has a front mounted blower installed went thru a costly repair only to find it failing again after a mere 10 hours of operation since the repair.
His first bill was $4000, and the second in the $2000 range.
The ultimate cause was that the PTO shaft had not been correctly adjusted for length when it was replaced following a Ujoint failure.
The 'pro's' simply wrote the failures up to abusive usage and never checked the shaft lengths for interferance.
Not very 'pro' in my point of view.
/ Lesson Learned: Pros Don't Always Do It Right. #8
There are people with 20 years' experience ....and those with one year's experience 20 times. Unfortunately, most of the time, unless you know the person doing the work - you don't which type of experience you're dealing with.
All true.
Now that I have a good night's sleep between me and the problem, I guess that I should add that I bear no malice toward the electrician. Like MMurphy said, I think he was just in hurry. My frustration was mostly with myself that I got tunnel vision that the problem had to be internal to the dryer.
I know it's been said a thousand times here on TBN, but many of us still forget it... "Start with the easy stuff first".
/ Lesson Learned: Pros Don't Always Do It Right. #10
When I was being trained as an electronics technician the 'Golden Rule' of troubleshooting was to always check 'E applied' (electrical source) first. Has saved me many hours of useless troubleshooting :thumbsup:
/ Lesson Learned: Pros Don't Always Do It Right. #11
You just have to remember there are career people that do a job for pay and there are professional people that do a job correctly just because it is a career doesn't make them a professional!!!!
Just look at some of the projects guys do on here it isn't their career but they make a product that they are proud of.
As I always joke about here you have to have plumbers license but electricians don't necessarily need one when was the last time some one got heart by a plumbing accident but many people have electrical accidents that go bad.
tom
/ Lesson Learned: Pros Don't Always Do It Right. #12
One thing to remember is that all "pros" that make a career are not really pro's. Many are real pros. When i did my electrician appreneticeship i was always mentored to the idea, "If you aren't willing to sign your name to it..don't do it"
I am one of the people with 20yrs experience, not 1 yr experience 20 times. The mistake that was made with the dryer outlet was a simple one that many experienced people would miss. I hate to admit but I probably would have made the same one.
Like the old saying goes...if you're satisfied tell others...if you're not satisfied tell us.
/ Lesson Learned: Pros Don't Always Do It Right. #13
Everybody has a brain fart occasionally. Several years ago a local contractor who ran the new electric residential services had one...he hooked up a hotleg to the customers neutral and the neutral to where the hotleg should have went. New house so just construction going on. Carpenters called complaining their power tools wouldn't work right...:eek: The kicker was the service cable was color coded, hotlegs are red and black and the neutral is white. He was SOOO embarrassed!:eek: Normally he did well above average work and very conscientious.
This thread sorta reminds me of an old saying. A fellow told a holier than thou sort of guy "Your going to church doesn't make you religious any more than me standing in a garage makes me a mechanic." :D
/ Lesson Learned: Pros Don't Always Do It Right. #14
I agree w this 110%.
I had a conversation w some of my contractor friends a few years back who said they must work fast to be competitive and get paid. They said I had the time to work slow and do a nice, neat, stronger, workmanship like, job. But somehow through some sort of twisted logic that I couldn't fathom, their work was better than mine!
(APPROX. 35) DIAMOND PLATE DBL AXLE FENDERS (A62131)
(APPROX. 35)...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
ROLL OF 6' CHAINLINK FENCE (A62131)
ROLL OF 6'...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
