Lesson Learned, Be Advised
   / Lesson Learned, Be Advised #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
Well, I have been hesitant to even post this because it is not likely to happen to most if any. But it is something to consider for anybody that is about to purchase a tractor, or anything else I guess.
I was recently able to demo a new tractor. Not sure how much time I actually put on it versus the hours it had, but when I finished using it only had 3.5 hrs. I parked it overnight on concrete. The next day I noticed fresh oil under the tractor, and with a quick look I determined that it was indeed coming from the new tractor.
I wasn't going to mention anything b/c it is not an issue with any particular tractor or engine, but I though it is something for buyers to be cognizant of. Who knows what would happen if I purchased the tractor without demo'ing? What if I had it for a couple of weeks before noticing the oil? Then the new tractor would be back in the shop for warranty work. Not something I would like to deal with. And sometimes dealers further away may offer a better price for a new tractor. But what happens if you get a new tractor from 500 miles away and you discover a leak?
So for me, I will demo any tractor before purchasing. Even though I may be familiar with and like a certain model, I still want to run the exact tractor that I am purchasing to ensure there are no issues prior to me paying.
Just thought I would pass along
   / Lesson Learned, Be Advised #2
I had a similar incident---While searching for a used tractor, I found one that had 156 hrs. and looked showroom new. I was checking it out from the dealer that sold it new. The FEL would not even raise the front of the machine at wide open throttle! The dealer had no comment, just showed me another tractor that I wasn't interested in.
Later, I noticed the tractor was sold---wonder if that person saw what I did?
On another tractor that I checked out, it was showing 195 hrs. Unbroken paint, on the engine drain plug, suggested that the tractor had not been serviced since new!
Buying anything, even new, warrents a thorough check out:thumbsup:
   / Lesson Learned, Be Advised #3
Even if you think the dealer is compentent and the tractor is brand new, you need to get into the OE manual and start checking everything you can possibly think of....and some that you don't even think of.... because you might be surprised that some major set up errors are present. For example some tires way over fill (like X3), some fluid levels way over filled to the point of running out when operated, some fluid levels way under filled to the point of just barely lubricating, some zerks with no grease, mowing deck not properly aligned. Those are just some of the things that I recall from a couple years ago. Heads up new owners.
   / Lesson Learned, Be Advised #4
Every GREAT tractor is only as good as the workers who assembled it........:confused2:
   / Lesson Learned, Be Advised #5
I don't know the particulars of this dealers setup situation, however, most dealers don't final prep a tractor until just before delivery. This leak would have been caught then by any competent dealer worth his salt. Ken Sweet
   / Lesson Learned, Be Advised #6
A good "heads up" for all...Thanks!
Don
   / Lesson Learned, Be Advised #7
Oh no! An oil leak! Darn BP! Call the White House!
Not intending to be offensive, but an oil leak is often, even usually a very minor item, something as simple as a slightly loose drain plug or oil filter. Sure, it would be preferable not to happen, but I don't think it's any indictment of the tractor, brand or dealer if it does happen. Generally fixed in minutes with no harm at all done.
There are various other minor problems that could come up. With my first new tractor, the shift knob kept coming off. Did I send it back and demand a refund? No, I had them fix it the first time (not realizing how extremely simple it was to fix), and the second time I got out a screwdriver and fixed it myself - permanently. No big deal.
A tractor is a piece of heavy machinery, not a Lexus, not a Japanese camera. Be ready for minor tinkering, even with brand new machinery from the best brands. If that doesn't sound like you, consider hiring out all the work on your property.
   / Lesson Learned, Be Advised #8
A few thoughts to add:
When my first tractor (which was Green, incidentally, and the last US-made green tractor in its class) needed that extremely tiny warranty fix, the selling dealer picked it up, fixed it at their shop in a day or two, and returned it, all at their expense and with no real hassle to me.
A good reason not to buy from a dealer that's too far away. I've decided not to buy if a quality dealer for the brand isn't within their radius of free pickup/delivery for warranty repairs. Each person should make their own decision balancing the desire for a particular brand/model, the lower price from a far-away dealer, and their mechanical skills.
   / Lesson Learned, Be Advised #9
Never really tried to ask to demo a tractor from my dealer, kinda thought he/she laugh in my face. I'm just an average home owner.
Do you by a lot from this dealer ?
No, first time actually.
Z-Mich, I would be worried what else was loose if they did not even tighten the oil plug or filter. But this appears to be coming from the crankshaft seal.
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2006 FREIGHTLINER CST120 (A53843)
2006 FREIGHTLINER...
Pickup Instructions (A47477)
Pickup...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
