Oliver Wendell Douglas
Front Pump Shaft Coupling Bolt Broke
I've got an L48 with less than 100 hours on it. A bolt broke in the coupler that attaches the drive shaft for the front pump to the motor's crank shaft. I stopped the motor immediately and removed the shaft and it looked straight. So I replaced the bolt and reinstalled the shaft. It runs and sounds good. However if a shine a flashlight on the shaft and look closely at it, it doesn't seem 100% true when rotating fast. Not so bad that you hear of feel anything, and not even noticible visually unless you shine a light on it and stare at it. Does yours run 100% true upon close inspection?
Part of the couplers are thin fiber disks. Are those intended to allow flex? I'm suprised a bolt broke rather than those disks
