Lenar Tractor
   / Lenar Tractor #2
How do you mean boosted.
Do you want to raise the relief pressure?
Do you know the pumps max psi potential?
A 2 in bore and 1 in shaft, at 2500 psi will have a force of 7,854 lbs
---------------------------------2950 psi----------------------9,268 lbs
If your system can handle the increase, you tighten down the valve relief adjustment.
You will need a 3000 psi hyd gage to do this.
   / Lenar Tractor #3
   / Lenar Tractor #4
Man look at that shipping cost
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2005 GENIE S-80 MANLIFT (A51246)
2005 GENIE S-80...
