Lely lotus tedder tine adjustment?
   / Lely lotus tedder tine adjustment? #1
AMorrison85
Kannapolis,NC
JD 5403
Having trouble getting my lely four basket tedder to spread hay evenly. It has two positions for the tines and a few on wheel height but haven't found the right combination yet. Mostly work in thick fescue grass and it tends to make two small rows instead of flat even distribution. Any advice on set up or ground speed would be appreciated.
   / Lely lotus tedder tine adjustment? #2
Slower rpm and faster ground speed for less spread. Sped up rpm and slow down will spread more. It can take awhile to find the best combination, especially if you have limited gear selection.
How long you let it dry will also affect how it spreads. Here in mid tn I like to let it set one day. I prefer to use low rpm and right speed to lightly lift it up in the air and criss cross in a tall pile .good airflow but sun doesn't bleach it so bad. Leaves slight rows of bare ground so sun heats it up.
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
43019 (A51691)
43019 (A51691)
Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
Toro Z-Master 6000...
Wolverine Quick Attach Rock Rake (A50515)
Wolverine Quick...
Land Honor Skid Steer 3 pt Adapter (A50515)
Land Honor Skid...
