Leinbach Post Hole Digger
/ Leinbach Post Hole Digger #1
SmoothSippin
Deere 2305 Deere 757
Has anyone had experience with a Leinbach 7300 post hole auger? I am looking at one, and was wondering if it will fit on a CUT. Specifically a 2305 JD. I have heard people have had height issues??? with PHDs on compacts... Any thoughts?
/ Leinbach Post Hole Digger #3
I have that same PHD, and I am happy with mine. I use it on my CC 7360. Unfortunately, our very rocky soil costs me many shear bolts. But that's not the fault of the PHD. For the smaller JD2305, you might want to look at the Leinbach 7200. It's sized for the subcompacts.
/ Leinbach Post Hole Digger #4
/ Leinbach Post Hole Digger #5
I have a Woods PHD25 auger with a 12" bit. Made for small CUTs and sub-cuts. Lots of clearance. Works very well in my extremely rocky soil.
/ Leinbach Post Hole Digger #6
/ Leinbach Post Hole Digger #7
I have a Leinbach 2300 on my Kubota B6100. The tip of the auger dragged on the ground by an inch or so when in the full up position. I took the auger off, cut down the top of the shaft 3" and re-drilled the mounting holes.
Now it will only dig 45" instead of 48" but I use it mainly for digging planting holes for the bushes/trees my wife keeps buying so the shorter auger doesn't bother me.
/ Leinbach Post Hole Digger #8
Thanks, I went to Leinbachs web site but I do not see this series listed. BTW, I am looking on ebay at this PHD, any idea what a fair price is?
Thanks for all the advise.
/ Leinbach Post Hole Digger #11
If I was you I'd take a look at the Tractor Supply PHD, it costs about the same as the Leinbach and their auger bits have a much better cutting edge and pilot. They are also reinforced where they bolt up to the PHD which will prevent the bit from breaking. John
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
