Posthole Digger Leinbach or Speeco PHD or are they same?
   / Leinbach or Speeco PHD or are they same? #1
wowwee
Central Wisconsin
2515 R
My next decision is the Post Hole Digger. I will be using it on a Kubota B2320, in sandy loam, that has some rocks. Which is better quality, Leinbach or Speeco? Maybe they are actually from the same manufacturer. Was cosidering a Land Pride for this too, but then someone mentioned that his Land Pride PHD also had China stamped on it. :eek: Hold my nose and pick the one that stinks the least.
Dale
   / Leinbach or Speeco PHD or are they same? #2
I looked up Speeco... I like the point on the auger. I have the Leinbach 7200 and the point of the auger is pretty small so it bounces around a little more then I like... I'm going to try and change out the tip to the longer screw type. Have you priced out either of them?
   / Leinbach or Speeco PHD or are they same? #3
Dale
No China anywhere on my Land Pride PD35. Maybe it is only the small units. :confused: PD10 and PD15 units?
Yes, I do believe it was the PD15 that had China on it.
The speeco and Leinbach are about the same price, $540-$570.
   / Leinbach or Speeco PHD or are they same? #5
I can't tell you if they are the same or which is better. I have a speeco that I have beat the tar out of and it has never given me any trouble.
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2016 Ford Focus (A50324)
2016 Ford Focus...
IH 1300 Sickle Bar Mower (A50515)
IH 1300 Sickle Bar...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
