Left wheel won't pull?
   / Left wheel won't pull? #1
Jeffjohnson11
John deer 870 series
I bought a HD 870 series tractor late 80's I m guessing. Clean tractor. Problem is the only way it will move is if I press the differential lock and only the rt wheel pulls. Shouldn't both wheels lick. And pull. Why won't the left wheel pull. Any suggestions. Thank you
   / Left wheel won't pull? #2
Welcome to TBN
Meaning John Deere 870.
Sounds like an internal gear problem.
Been this way since purchase? Or know of an event that may have caused the issue?
   / Left wheel won't pull? #3
I agree. It sounds like a problem within the differential. The tractors I've seen normally pull on the right wheel. The differential lock adds the left wheel.
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51691)
2013 Mitsubishi...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53473)
2018 John Deere...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
