Left front noise identified--BX25D
   / Left front noise identified--BX25D #1
frogpond
Snohomish WA
Kubota BX25D
In case this helps anyone: Recently, I started hearing a pop/snap/click noise from the left front of the tractor. It was rhythmic when going forward or reverse, especially active when turning left. I checked the drive shaft u joint, even though it's on the other side, as it had been a problem in the past. I checked the plastic sleeve over it. I tightened the castle nut on the central axle pivot. I greased the ball joints. Nothing helped.
Finally, I jacked up the front end, using the loader bucket. I spun the wheels. Luckily, no noise from Inside the axle assembly.
At that point, I removed the left wheel. 3 of the 4 holes were oval, not round. Probably the bolts had loosened at some point, and worked in the holes enough to cause this. I think the noise was from the resulting slippage as the wheel revolved. I remounted the wheel, and cranked on the lug bolts.
The noise stopped. The right wheel was okay. I will replace the left wheel if the noise returns.
   / Left front noise identified--BX25D #2
I think you will need to replace the rim in the long term. Once a stud hole is ovaled, it will always keep working loose.
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
UNUSED 2-Pack Black Outdoor Patio Fabric Screen (A50860)
UNUSED 2-Pack...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2016 Ram 4500 Wheeled Coach Ambulance (A48081)
2016 Ram 4500...
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
