Left front axle bevel gear housing
   / Left front axle bevel gear housing #1
justjoey34
Kioti DK40SE
I had a major failure on my Kioti DK40SE when the outer axle bearing broke apart along with the seal kit and also cracked the outer case. (overloading the FEL my fault) but I'm having trouble locating the case and seal kit parts that are the proper size. OD of seal is approx. 3" and OD of inter bearing is approx. 3 5/8". Any suggestions?
   / Left front axle bevel gear housing #2
Can't help you with the parts, other suggesting for you to contact the dealer, but keep in mind that everything will be in metric on that tractor. That bearing is most likely 92 mm OD and the seal 76 mm OD.
The bearings you should be able to easily get on any bearing supplier. The seal might be a bit harder and you may end up to get it through the dealer.
   / Left front axle bevel gear housing #3
I’d start with dealer. I spent a ton of time trying to source seals through Alibaba and eBay and Banggood and the like and just ended up at dealer. Some seals are a fraction of the dealer cost while others are similarly priced.
Thanks for the reply. I knew the measurements would be metric but didn't have a mic. you're right the bearings were easy to come by and the dealer has contacted Kioti directly over a week ago and is not getting any reply so I'm trying to see if someone else has run into this issue and had success through an aftermarket supplier
2012 Ram 3500 Crew Cab Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
Road Drag (A50514)
Road Drag (A50514)
John Deere 7810 Tractor W/Loader (RIDE AND DRIVE) (A50774)
John Deere 7810...
2016 Volvo SD45 Smooth Drum Roller (RIDE AND DRIVE) (A50774)
2016 Volvo SD45...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
