Leech Field Collapse-Repair Help
   / Leech Field Collapse-Repair Help #1
ben2go
Upstate, South Carolina,USA
My septic system leech fields drain lines have collapsed and caused a sewage back up into the house.
My current leech fields are set up like this.
I would like to flip it, run my gravel,then my drain lines with black plastic membrane over everything.There is a slope from the upper end of the drain field to the lower end.Luckily there are no trees or bushes around to cause problems.
Any advice.
I am trying to find the records of the original perk test.I know there are two leech fields.I think each gravel pit is 6'x6'x80' with 3' of soil over that.My uncle did the original install but he passed last year.
   / Leech Field Collapse-Repair Help #2
Around here, you would need a leach field designed or signed-off on by a licensed person and a permit when doing a replacement system. I have no idea if your idea is good or bad for your local conditions. How long did the existing field last? Must be pretty old if the pipes collapsed.
   / Leech Field Collapse-Repair Help #3
first of all -- how do you know it collapsed? if it something causing a backup into the house - then it must be before the distribution box. If one or two leeches lines failed - then the other lines should pickup the slack somewhat. I would start by looking at your survey map and see if the lines are drawn on it and start from distributions box and start your detective work from there. Its possible you dont need the whole new leech field. Why put in a new one if you dont know why it failed? If you designed a new leech field based on old test and it not up to par - you are just setting yourself up for failure down the road.
   / Leech Field Collapse-Repair Help #4
Any advice.
My guess would be your septic tank needs pumping-have you confirmed you don't have a solids issue in the tank.? I would confirm that the tank is not full. My septic guy told me the last time I had mine pumped, my solids were so high, when you get that condition you can get a run off into the leech field system. He told me to expose my distribution box to insure I had no build up there. Well I exposed it, and when I took the cover off, it collapsed! 20 year old system-never would have thought pre-cast concrete would deteriorate like that but it did. In any case, I had no blockage in the D box and everything was ok.
Again, check your tank.
Existing field made it from 87 till 10 years ago when there was a partial collapse of one drain line to the leach field.A replace here doesn't require permits and sign off because I am in the county.If I was resetting a new system or changing to a different system,I would need permits and sign off.
The lines were scoped 10 years ago when we had a back up and the tank was cleaned out.I am assuming they have collapsed more.We have had a deluge of rain this past week.There's a slope over the drain fields and water runs off more than it soaks in.Last year I had a main line from the house to the tank come apart.I had the tank pumped then.Very little sludge.Mostly water and it was backed up.The guys said they felt the leach fields need replacing.I wasn't with them when they cleaned out the septic tank that time,so I have no idea if they checked the lines.My property map/plat has nothing on it.It only shows they property boundaries.My plan was to add length or a third leach field.
That reminds me.Our systems don't use junction boxes.All of ours use black corragated piped with T fittings to plumb to the leach fields.As stated above.The tank was cleaned out last year when I repaired a main line that separated.fortunately it was under the house.
I talked to a guy that said he had a few options and is willing to work with me.He is licensed and experienced.I'm rounding up the funds and I will call him,hopefully before the weekend gets here.
Now I have to get on tearing out the bathroom for new sub floor,lower walls,and vinyl.The floor is OSB.It's soft and sagging.Someone,not me,caulked the toilet to the floor.I went under the house and seen where the seal had been seeping for a long time.All this rain finally put enough pressure on the wax seal, and caulk, to blow it out.What an f'in mess this is.It actually ran under two walls and got into some carpet.This isn't going to be a fun weekend project.:smiley_aafz:
   / Leech Field Collapse-Repair Help #7
Sorry to hear your troubles are coming in three's.
I would not use corrugated black plastic pipe in a leach field if you make changes there.
   / Leech Field Collapse-Repair Help #8
Ben2go you are going to have to contact the county DEHEC office they will come out and tell you how to repair your system and inspect it during the repair process. I had the same thing happen 9-8 years ago it was not a fun week in my house!
   / Leech Field Collapse-Repair Help #9
On the toilet seal: I had an addition put on recently. The code used locally required the toilet to be caulked to the floor. I wouldn't have done it, but that was code. I am in favor of knowing the leak a LOT sooner than later.
   / Leech Field Collapse-Repair Help #10
Sorry to hear of your troubles.:(
Oh that lovely OSB board ! There should be a law against that stuff.
Does your septic tank have a filter on the outlet. If not consider installing one to catch inorganic fibres.:)
2017 Ford F-150 (A44789)
2017 Ford F-150...
VOLVO EXCAVATOR  EC330CL (A45046)
VOLVO EXCAVATOR...
2017 Chrysler Pacifica Minivan (A42744)
2017 Chrysler...
2005 Chevrolet C5500 ETI 29 SNV Enclosed Bucket Truck (A42742)
2005 Chevrolet...
2018 Ford Transit Z50 (A44501)
2018 Ford Transit...
2014 DRAGON PRODUCTS DRAGON PRODUCTS (A45333)
2014 DRAGON...
