Learning to use a Box Blade (my personal journey)
   / Learning to use a Box Blade (my personal journey) #1
wagne223
Platinum Member
Debary, FL
Kubota L2501
It is often said that the learning curve is long on a box blade. Because of this many users simply use it for a counterweight.
I wanted to share my experience with learning to use a box blade. Maybe it will help someone new to this versatile tool or maybe fellow TBNers just may enjoy the read.
I am a hobby tractor user in that I really only use my tractor to maintain my hunting property. I am typically on the tractor for 50 -75 hours per year. My tasks are primarily mowing and pulling a disc harrow. Occasionally I need to repair roads, clean ditches and clear tree debris from logging operations.
I started by borrowing a friend's B series Kubota. It had a 4ft BB on it. I know nothing other than that about the BB. The tractor had the typical manual adjustments for the 3PH. I read some and watched some videos on BB use. Got on site and tried to move some material around. What a daunting task. The only real control is raising and lowering the 3PH. Angle of attack adjustments were difficult and time consuming.
I was able to move a pile of material from one location to another, however the material had to be piled already. I was also able to scrape a logging area of tree debris mainly by using the rippers as a rake. What I could not do was get the BB to effectively scrape and smooth the roads that are made of sandy clay. I also could not make any repairs to the roads. I would simply make them worse.
After a few sessions, I labeled the BB as good for nothing but a counterweight and simply did what I could with the FEL.
A few years went by and I decided to buy my own tractor so I started researching. While researching I noticed people talking about Top and Tilt.
So after figuring out what that was, I researched how that helps with a box blade. I had also read discussions on Weight for a BB and took the advice to get the heaviest one that was in budget.
So I ordered my L2501 with top and tilt, and I ordered the Landpride BB2566 box blade.
I used the tractor for mowing and disc work, but still had not really tried the BB. It has rained a lot since last summer and the roads a camp are getting bad. So I decided to watch some videos on how to use a BB. One guy named Dave Knows How on you tube gives a great instruction video.
I went out this past weekend to implement some of what I have learned. The most important thing I learned was.......
With a hydraulic top link, a box blade is a completely different tool! Being able to easily make adjustments in angle of attack while operating makes a huge difference in how the BB works and my ability to make it do what I want.
Angle forward a bit to put the rippers in the clay and the box fills right up. Once full, tilt back a little to stop cutting and just drag the material where needed. To evenly spread material, set the 3ph arms where they just start to raise the BB, then drive forward while tilting the BB forward (shorting the top link) and the material just evenly flows out. To pack and smooth, I tilted the BB all the way back (full extending the top link) and drive across the area.
Now I still have a lot to learn, but I'm really happy that I now can use this tool for what it was designed for.
My recommendation to anyone that wants to use a BB is get hydraulic top and tilt for your tractor and get a heavy Box Blade, It truly makes a world of difference.
   / Learning to use a Box Blade (my personal journey) #2
Did you get the "tilt" as well? You just mention how the "Top" in Top & Tilt helped you out.
I also recommend T&T for boxblade users. YEs, you can certainly accomplish the same thing by manually adjusting your top link and side link, but in practice, you will never end up making those adjustments as well and as frequently as you should if you are adjusting them manually. As a result, you end up either spending a whole lot more time, or accepting "good enough".
Yes, I got both. Really have not utilized the tilt yet. I was just amazed at how much the top link helped.
   / Learning to use a Box Blade (my personal journey) #4
Congrats on getting a nice set up rig. As you posted the top and tilt makes things so much easier and faster. Manual works but is much slower and not very efficient. Sounds like your well on your way of getting it all figured out 🤠
   / Learning to use a Box Blade (my personal journey) #5
Hard to find anything better than T-N-T. Takes SO MUCH frustration out of blade and rake work. Makes the learning curve FAR easier and productive. I might add, adding wheels to the back of a good rake is another order of magnitude improvement.
   / Learning to use a Box Blade (my personal journey) #6
A friend of mine can't effectively use a BB. Absolutely cannot. Every pass makes the project worse. There's a mental block there somehow..... :)
That is funny.
I think there are 2 processes. First is knowing what you need to do with the soil or material. Move material, cut the high spots, fill in ruts and holes, smooth and shape, ect.
Second is getting the equipment to effectively do what you want.
Personally I could look at a project and know what needs to be done. I just had a tough time getting the equipment to do what I needed.
Once I got the T & T and heavier BB, I just hit a section of road and started testing different things. It just started to make sense after a while.
Few more years and I might be good at it!
LOL!
   / Learning to use a Box Blade (my personal journey) #8
TnT and Position Control 3pt help a lot!!! My friend has both and still can't master it. He bought a land plane and a pull type box blade and gets along fairly well now.
   / Learning to use a Box Blade (my personal journey) #9
I find that running in reverse is best for good smoothing work. I'll do rough work going forward, but "finish" going in reverse (pushing). If possible (either forward or reverse) I'll go over an area at differing angles (and sometimes, in a fairly open area, I'll go in circles) overlapping.
Hydraulic top-link is essential.
   / Learning to use a Box Blade (my personal journey) #10
Getting a Box Blade drove me to get T-N-T, based on the first few times I tried to get anything done with the Box Blade.
I was surprised to see how productive my time with the Box Blade became once I had the T-N-T installed.
T-N-T also transformed my 3PH Forks from the most frustrating implement I'd ever used into a very effective pallet handler.
-Jim
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
HYSTER H60XT FORKLIFT (A52472)
HYSTER H60XT...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
