Learning experience
   / Learning experience #1
Waffles
SLO, CA
MT225HE
I have a steep concrete driveway in front of my house. I always run the tractor in 2wd on it. Over the weekend I was loading a pallet in front of the house with the tractor up hill on the drive. I lifted the pallet and started down the drive aimed at the house. Hit a small bump in the concrete that started a slide. My first reaction was to add brakes thinking my increase in speed was just the steepness of the hill. By the time I figured out what was happening I was going too fast and too close to the house to drop the load. I was lucky to be able turn to flatter ground missing the house by a couple feet.
Lessons learned:
Need more ballast. I knew this already but I don't have a way.
Keep heavy side up hill, even if inconvenient.
Use 4wd with any heavy front load, better to be safe than worry about wear and damage to driveline.
I don't have an easy way to add weight to my BB.
   / Learning experience #5
Second on the filling of the rear tires.
Mine are filled. And after breaking my last tractor twice trying to lift more than it could handle.... I dont use rear weight for any reason.
I let the tractor tell me its too much.
Filling the tires is not as efficient as adding weight on 3PH. I need to be efficient because the HST struggles on my steep hills. I need to be able to easily add and remove ballast based on tasks.
   / Learning experience #7
That's just crazy advise.
Your loader manual should cover this. My LS manual says I need both. Tire ballast, liquid or steel weights, and a counterweight on the rear.
It does. I need to figure out how to add 500 pounds on top of my BB.
   / Learning experience #9
Hang some suitcase weights off it.......
SELLICK S80J4E-4PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-4PS...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
2013 Chevrolet...
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
