Bob_Skurka
Super Member
- Joined
- Jul 1, 2003
- Messages
- 7,615
I took the Kubota B2910 to the warehouse where we have an overgrown field that is filled with scattered debris. I couldn't use a bush hog because as I inspected the field I found a KITCHEN SINK, several tires, some pallet racks, a TV antenna and lots of other stuff. All that stuff had to be revomed so I went to work with the FEL basically scraping the area clean and mounding the debris up in piles so it could loaded into a roll off dumpster.
Somehow in the process I seemed to have damaged a valve stem on my left rear tire and I started hearing a hissing sound. Took the tractor right into the back of the warehouse and threw a truck jack under the rear end to take the weight of the tractor off rear tire.
My question is can the valve stem be repaired without removing the entire wheel (which is fluid filled) and dealing with the mess of fixing a fluid filled tire?
<font color="green"> On a side note, since this is a work related repair on a personal tractor, can the repair be paid for by the company and deducted as an expense? </font>
