Leaky valve assembly
   / Leaky valve assembly #1
pmon
I have a bx22 and have had a leaky valve assembly for the backhoe. The diamond shaped plates that the control pistons go through hold down a nylon type washer against the seal. The plate gets bowed up and the washer forces its way out until it is shaped like a tear drop and allows hyd. fluid to leak. This has happened on all the valves even the leveling feet which I can not see how I could over load them if it is an overloading issue. Has anyone seen this happen , what is causing it and how can I resolve it. Thought I would ask before I get stuck with a large repair bill.
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
John Deere 1020 Tractor (RUNS) (A50774)
John Deere 1020...
Gehl 2580 Round Baler (A50774)
Gehl 2580 Round...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
6-Row Rolling Cultivator Narrow INOPERABLE/PARTS ONLY (A52128)
6-Row Rolling...
