Leaks on new GC2310
   / Leaks on new GC2310 #1
DannyLobster
Bronze Member
SW Florida
Massey GC 2310 TLB, Gravely 526
So I got to play on my new ride. After a couple of hours I gave her a look over and noticed one hose on the loader appeared to be leaking. It felt tight though. How torqued should these fittings be? Is there a way to better locate the leak?
Of more concern was what I thought was a fair amount of fluid which appeared to be coming from the Hoe's control levers. Is this normal or expected?
/forums/images/graemlins/confused.gif
Thanks Dan
Thanks Dan
   / Leaks on new GC2310 #3
This is not normal. On a new machine you should have no leaks. I had a leak on a metal connector of my Fel line on a new Kubota B2410. This was a slow drip. I had no luck trying to tighten it. I called the dealer who promptly repaired it under warranty with no charge. I would let your dealer take care of the problem.
   / Leaks on new GC2310 #4
   / Leaks on new GC2310 #5
I would say that they didn't get them on tight enough. Did you put a wrench on the hose that you said looked to be tight enough?
   / Leaks on new GC2310 #6
Yes I did put a wrench on it and it felt tight but I have not run it since. I did not torque it.
There is definately more coming from the hoe control. I think I need to call my dealer. Isn't that what warrenties are for?
Dan
Dan
   / Leaks on new GC2310 #9
Your dealer should take care of it for you. If it is real simple, sometimes it is just easier to do yourself. That is if it's only to tighten up a fitting a little. They can be over tightened and broke, so it would be better is the dealer did that. /forums/images/graemlins/blush.gif
   / Leaks on new GC2310 #10
2005 Ford F-350 4x4 Crew Cab 8ft Dump Truck (A48081)
2005 Ford F-350...
45029 (A48082)
45029 (A48082)
East Texas 40ft T/A Gooseneck Trailer (A48081)
East Texas 40ft...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A48836)
2013 International...
Heavy Duty Plate Compactor (A47371)
Heavy Duty Plate...
2022 Polaris Ranger XP Northstar (A47371)
2022 Polaris...
