Leakink fuel pump
   / Leakink fuel pump #1
The Cub
Cub cadet 1250
My cub 1250 has a kohler magnum 10 engine and was leaking oil from where the fuel pump bolts to the block. I have gone ahead and changed the gasket and its still leaking any ideas ??
   / Leakink fuel pump #2
Hi,
I have a 1811 and just replaced the fuel pump last month - its the lever action type pump runs off a camshaft near the top of the engine.
The bodies of the fuel pump are a hard plastic (at least mine were) and if its still leaking I would suspect a broken body or possibly a warped pump base. These pumps and seals inside dont last with the methanol in gas these days.
You can find replacement pumps on ebay - kohler OEM type - thats what I did and now my 18HP magum starts much faster with very little choking required.
Do you notice the oil level increasing or smelling like gas? If so your pump is leaking gas into the oil - it starts out slow and over time increases and eventually they wont start, also the leaking/seaping of gas in the area could degrade the gasket and look like an oil leak.
   / Leakink fuel pump
Thanks for the info , sounds like we've got the same pump. I'm going to take mine off again and check the housing for cracks.
14ft trailer 12 ft deck (A51694)
14ft trailer 12 ft...
2018 GMC 2500 4x4 Crew Cab (A52384)
2018 GMC 2500 4x4...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
Miscellaneous Kitchen Equipment (A53117)
Miscellaneous...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
