mntnvew
I have a 3pt log splitter, a speeco, that I have had about 2 weeks. Yesterday afternoon I was using it and the lever got stuck, so I turned off the tractor and disconnected the hyd. hoses and then attempted to move the lever from the stuck position, it moved but all of a sudden hyd. fluid started to leak out of the "spring cap for valve" (quoted from the manual's parts list). If you go here you can see what I mean:
http://i405.photobucket.com/albums/pp140/mntnvew/tractor/splitter-hyd.gif
What do I need to do to repair? Anyone have any ideas? There are two small allen bolts holding the cap on. In the essence of not losing any parts, do I need to order a new part to fix this (rubber washer or something???).
Any ideas, I just dont want to take it apart only to find out I made it worse.
ANY insight is greatly appreciated!!!
PS - Does any one know WHY this occurred? My tractors hyd information is as follows:
Hydraulics:
Type: open
Capacity: 5.4 gal [20 L]
Total flow: -unknown-
Valve flow: 11.7 gpm [44.3 lpm]
Pressure: -unknown-
Valves: 2
The pressure is UNKNOWN, the log splitter manual says the max pressure rating is 3200 PSI, could it be that my tractor is putting out more PSI then the max allowed? Could that have caused this?
Is there any contraption out there that will measure the PSI my hyd is putting out to see if it exceeds 3200 PSI? (Not to mention it would be nice to know!)
Thanks!
Hydraulics:
Type: open
Pressure: -unknown-
Valves: 2
Thanks!
