Leaking Quick Coupling
   / Leaking Quick Coupling #1
ritcheyvs
Veteran Member
Kittrell, NC
Kioti DK45S
One of my quick couplings has a slow leak. This is a brand new coupling set. Have others has this problem? Has anyone solved it? Thanks.
   / Leaking Quick Coupling #2
If it is a new set take it back where you bought it. Beware of foreign made knockoffs of US name brand QCs, not always well matched. Probably the O ring as it easy to mess them up on first use if not lubricated with hyd fluid. Rough machine work QC knockoffs can have a burr that kills O rings.
Ron
   / Leaking Quick Coupling #3
Does it leak when connected or with nothing connected to it?
   / Leaking Quick Coupling #4
Best bet is get another pair of couplings. Short of that, if its the male, beat on it with a piece of soft wood to reset the detent ball. If its the female, try small bursts of low pressure compressed air, while holding the fitting away from your face/hands to see if maybe there is some debris, or similar. Does it leak when coupled or uncoupled? Is it the male or female giving you the problem?
Thanks for the info.
The coupling leaked while connected. I didn't check for leaks with it disconnected but that hardly mattered since I couldn't use the coupling. The leak was bad enough that I couldn't fully close the grapple or start closing it from full open without help from gravity. There is a flow restrictor in the "close" line of the grapple.
I bought a new coupling today at TSC and installed the female side. That fixed the leak and the grapple works like it's supposed to now.
I have a related question but I'll start a new thread.
OK. Here's the deal. I replaced the leaky female coupling with a new Pioneer double-acting coupler and thought it was fixed. But today I noticed it was still leaking, albeit much slower. So I replaced the male side today and that fixed the leak (so far). The "leaky" male fitting looked fine but I guess the finish or dimensions weren't good enough to seal. The " leaky" no-name coupling set was made in China.
   / Leaking Quick Coupling #7
I had a leaky Chinese Male coupler. Constant drip, about every 30 seconds. Replaced it over a year ago with a pioneer. End of problem.
KJ 8'x6' Powder Coated Steel Site Fence (A50121)
KJ 8'x6' Powder...
John Deere 6115D (A50120)
John Deere 6115D...
Caterpillar Loader Quick Coupler (A52748)
Caterpillar Loader...
1000 Gallon Fuel Tank (A50121)
1000 Gallon Fuel...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
Electric Mobility Scooter (A51694)
Electric Mobility...
