Leaking Lines
   / Leaking Lines #1
Billlipka
Kubota BX2200
Hello
I am a new member to this site. I have a Kubota BX 2200, 9 years old and have been replacing original hydraulic hoses left and right the past 2 weeks on the front loader system, is this normal?? or is there a pressure issue? the new hoses are fine it's the older ones that are leaking. Does someone have a diagram to share also?
Thanks I am at wits end here in Ma.
Bill
   / Leaking Lines #2
You may try tighten up the fittings, but if the hose is leaking, it is time for replacement.
   / Leaking Lines #3
Hello
Bill
Welcome to TBN:D
Seems I remember that a lot of the early BX's had/have the same problem. I guess they used cheap hose? Search some, you will find threads telling the same story.
2015 Nissan Altima Sedan (A51694)
2015 Nissan Altima...
2008 Ford E-150 Cargo Van (A51692)
2008 Ford E-150...
2014 Ford F-150 (A53422)
2014 Ford F-150...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
