leaking joystick valve dk55
   / leaking joystick valve dk55 #1
bbtaxidermy
I have a major problem with my joystick valve leaking around the spool caps I am forever tightening them and when the loader is used they always leak. Two days ago I loaded 100 round bales or so and the leak was real bad very high pressure spray from caps any time the bale was on and I was moving loader any suggestions on a cure for this problem. Thanks, Wes
   / leaking joystick valve dk55 #2
Well, I don't have a solution to your problem, but my grandpa's new Kioti hystat's spool connectors leak too....leaked from pretty much day one. He also has a bit of a power loss problem - he plans on taking it in after the first of the year. Still under warranty, so it's not too big a deal.
thanks for the reply, My Kioti is out of warranty unfortunately or I would take it in I was sure hoping that one of the hundreds of members would maybe have had the same problem but I guess it is my just my luck to have some kind of weird problem thet no one has had before. Thanks, Wes
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
Krone Swadro 46T (A50120)
Krone Swadro 46T...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
