Leaking Jinma 224 Radiator (video inside)
   / Leaking Jinma 224 Radiator (video inside) #1
jbrukardt
Bronze Member
Maryland
none
was moving some mulch yesterday, and noticed my temp was getting into the red, immediately shut down when it was about 110 (not sure if that gauge is C or F, i presume C), and checked my fluids. I had almost nothing in my radiator.
Refilled it, and am getting a steady drip out of it unfortunately, but in a strange place. Its dripping off the alternator pulley.
Took a quick video, any idea where this leak might be coming from before i start tearing things down?
   / Leaking Jinma 224 Radiator (video inside) #2
The Water Pump is leaking and there are seals in there on inside that might be replaceable but probably about as cheap to replace the pump.
Call Tommy at Affordable in TX and see if they have seal kit or new water pump.
Mark
got a diagram of where its located? it was kinda getting dark when i took the picture, i figure its just a bolt on, attach a few hoses type thing
and as always, thanks a bunch mark, always appreciate the help here
   / Leaking Jinma 224 Radiator (video inside) #5
Yep, its a leaky water pump, we have the replacements we just need to know what engine you have ,we are open until noon on Sat. if you want to call and order 979-865-4002 or order online
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
www.affordabletractorsalesco.com
Tommy
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Thanks Tommy,
I have the Yangdong Y380. Is a seals kit available, or do i have to buy the whole pump? Im due for another order from you anyway, so if possible id like to order from the website so i can get my other stuff as well.
   / Leaking Jinma 224 Radiator (video inside) #7
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb. 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
2013 BMW 528i Sedan (A50324)
2013 BMW 528i...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
