Leaking hydraulic plug
   / Leaking hydraulic plug #1
Mtnlover64
Walsenburg, Colorado
JD X585,Mitsubishi/sakoh Beaver,ford 195
Hello, I have a leaking hydraulic/ differential plug on my JD x585 and I'm trying to find the best way to fix it. The differential housing is aluminum- the plug steel, I've tried wrapping Teflon tape around the plug but it's still leaking. The threads in the housing are almost stripped out. Someone suggested Teflon paste but I'm not sure if that will help, the plug is only 1/2 to 3/4 inches long, any ideas ?
   / Leaking hydraulic plug #2
Can you drill out the hole and tap new threads for a plug of the next largest size?
   / Leaking hydraulic plug #3
If memory serves me right, auto supply shops carry self tapping oil change replacement plugs just for that purpose.
Might be worth checking that out. Be sure to get the smallest to do the job, i.e. just a tad oversize.
Good luck.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
AUCTION STARTS HERE @ 9AM (A52705)
AUCTION STARTS...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
