Leaking Hydraulic cylinder
   / Leaking Hydraulic cylinder #1
bky
Northern Kentucky
l245dt
Hi I have a Kubota model 1200 loader on an l24dt and the cylinder is leaking. I am not sure if the parts to fix it are still available to fix it.
And suggestion on it?
Would it be better to buy a new one or rebuild the old seals if I can find them? Thanks to all in advance. Bill
   / Leaking Hydraulic cylinder #2
Most seals are just O rings. Be sure that you get the type that are compatable with the fluid you are using for hydraulics. /forums/images/graemlins/wink.gif
   / Leaking Hydraulic cylinder #3
I do believe that if you call your local dealer, they can get the seals and rings for you. You might want to dismount the cylinder and take it in, if your dealer's shop is well equipped, they can do it for you as long as the hard chromed cylinder rod isn't scored. That's usually the cause of seal leakage.
   / Leaking Hydraulic cylinder #4
Save some money and take the cylinder to a local hydraulic shop and ask them for the appropriate replacement parts. I rebuilt two of mine on my IH656 loader for about $40 in parts, not including the polishing of the shafts that I had someone do.
- Gerald
   / Leaking Hydraulic cylinder #5
bky,
I had a 1200 loader and rebuild kits are available from Kubota, but as suggested take it to a local shop and they will rebuild it for $40-80 depending on the repairs needed. If bent tho it could get expensive.
CArl
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
Howse Mower (A50121)
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
Ford Tractor (A50120)
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
