Leaking Gas Tank / Fuel Line
   / Leaking Gas Tank / Fuel Line #1
dceonline
...on an older Bolens lawn tractor - it looks like it's leaking right where the fuel line connects to the bottom of the tank.
So, how do I repair this? It seems a little loose, but I don't know enough about how the connector is attached to the tank to know if it's something I can tighten or replace or ?? Is this typically the same kind of connection for most tractors or are the connections unique to specific tractors?
Any help greatly appreciated...
   / Leaking Gas Tank / Fuel Line #2
Don't know that unit, so my advice is strictly generic. If it's a crack, rather than a leaking joint, JB Weld will fix you up.
   / Leaking Gas Tank / Fuel Line #3
As blueridge said, If it is a molded onto the tank nipple, glue of some sort will be required. JB weld will probably work, get it good and dry and rough it up a bit and let it set for about 24 hours before putting strain or gas on it.
Ben
Ok, I pulled off the gas tank. There is a little stem (that the gas line attaches to) which goes into a rubber bushing, which plugs up into the plastic tank.
I don't see any problems with the body of the tank - it appears to be leaking from the hole/bushing - the bushing looks to be in good shape and plugs in firmly - doesn't seem cracked or dried out...? It seems that the hole it plugs into might not be perfectly round - maybe that is the cause?
If a replacement bushing doesn't work & it turns out to be the hole itself, any way I can augment that hole somehow? Would the stuff you're talking about work with a plastic tank & in this application?
   / Leaking Gas Tank / Fuel Line #5
</font><font color="blue" class="small">( If a replacement bushing doesn't work & it turns out to be the hole itself, any way I can augment that hole somehow? Would the stuff you're talking about work with a plastic tank & in this application?)</font>
Yep. Once it cures, you can sand it or drill it or whatever you need to do, and gasoline doesn't bother it.
DONE. And it appears to have worked. Sadly, I have suddenly noticed another problem which I will post separately. But thanks for the help offered here I really appreciate it!!
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53473)
2020 Westfield MKX...
2 MONITORS:  HP & SAMSUNG (A53843)
2 MONITORS: HP &...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53473)
Kubota SVL65-2...
