Leaking front axle
   / Leaking front axle #1
greedy 737
Lenhartsville PA
Kubota B7500 HST
On my B7500 it leaking oil at the seal near the nuckle! Not to bad but its getting worse when its hot out. I know they can build pressure but it never leaked before! I switched to 80-90w gear oil about two years ago. Is this a known problem, and how hard is it to fix? Does anyone have a wright up on how to take it apart to replace the seals. Anyone else have or had this problem? I am a mech. just never worked on this type of axle! Thank you!!
Hope everybody had a nice and safe Holiday weekend! Sorry for the OT..
can I give my self a bump? Starting to leak alot more today!!
   / Leaking front axle #4
The front axle leaks appear to be common on all four wheel drive tractors, but ones that do a lot of FEL work are usually the worst. Seems like these are fairly easy to do with common hand tools, but I suggest getting at least a parts breakdown from the dealer or better yet a repair manual.
BTW - mine are weeping a little, but not enough to lower the level of gear oil. So I'm putting it of for another year or so.
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
JOHN DEERE 8410T TRACTOR (A51243)
JOHN DEERE 8410T...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
