leaking from the brake system
   / leaking from the brake system #1
cfoxmd
North of New Orleans
FX28D
My FX28D has a leak. The leak is from a hose that goes from the upper transmission to the brake cylinders. It carries the 303 fluid to the brake system. What type of hose should I use to replace it? Fuel line, transmission?
   / leaking from the brake system #2
Is it a pressure line? or a return/suction line.
if it is a pressure line, I imagine fuel line will blow quite easilly. Check to see if it is a metal belted line.. if so.. replace with a equaly rated psi line.
Soundguy
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
2013 Doosan Light Tower (A51573)
2013 Doosan Light...
Modine Shop Heater (A51573)
Modine Shop Heater...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
