Leaking cylinders
   / Leaking cylinders #1
Bob trike
Kubota B21
Hi all. I have a Kubota B21. Right now it has two leaking cylinders on the front loader bucket. I bou the seal kits. How do I put them in? Do I need any special tools?
Thanks for any help.
   / Leaking cylinders #2
No special tools really. A pair of inside snap ring pliers to compress the retaining ring at the cylinder end. The tips need fit the ring holes.
A good vise to hold the rod while you loosen and tighten the piston nut. A block of wood to set the rod on when taking the piston nut off so as to not scratch the chrome.
Alternately, instead of a vice, you can leave the cylinder pinned to the bucket, remove the cylinder tube and keep rod steady to remove the piston nut.
Other than that, a good clean surface to work on.
Starting fluid works well to clean the parts of the cylinder.
Giyi Dingo Backhoe (A50774)
Giyi Dingo Backhoe...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
John Deere 3033R (A50120)
John Deere 3033R...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
Horsch Joker RT32 Speed Disk (A50514)
Horsch Joker RT32...
